We have a file server cluster with four nodes. Each node has a certain number of resources (drives) which can also move from one node to another.
The second node had to be taken out of the cluster a few weeks ago and is now operational again. If resources move to this node, they can no longer be backed up, because the Commvault plugin does not recognize this.
It only works again when I select the resource in Commvault and then perform a manual synchronization.
Has anyone ever had this problem ?
I also have a few screenshots attached to visualize the problem a bit.
Regards
Thomas
Best answer by thomas.S
