Qscript / SQL Stored Procedure BackendStorage
  • April 5, 2022
  • 353 views
ApK
Apprentice
Hi All.
I’m using the BackendStorage (QS_BackendStorage) Qscript / Stored Procedure to calculate backend storage usage for a given customer, to be able to invoice the customer for backend storage usage.
When sealing a DDB, I would like to exclude the storage usage from that DDB, would this be achievable, either by a command via the qoperation executing or by editing the QS_BackendStorage Stored procedure in SQL?
-Anders
Best answer by Matt Medvedeff
Hello @ApK
You could try modifying the i_fromTime variable to a date after the DDB was sealed. This should only report on Data written after this date
Usage
qoperation execscript -sn BackendStorage [-si @i_fromTime='2013/02/12'] [-si @i_toTime='2013/02/20'] [-si @i_isAged='2'] [-si @i_backupType='Full'] [-si @i_orderBy='Client'] [-si @i_policyName='policyName'] [-si @i_copyName='copyName']
https://documentation.commvault.com/11.24/expert/BackendStorage.html
Hello @ApK
Usage
