Recover Web Console Password
  • 4 December 2023
  • 60 views
Good evening.
If someone is new in a Commvault environment, how do I recover user credentials for both web and java console. Commvault solution was configured by someone but left the company. What effort does it require to access the consoles?
Kind Regards,
Tshepo Chiloane
Badge +14
@Oracle ,
We would need to go inside the Commserve DB.
If you have the SQL password for sa, that will be useful.
So the best is to log a case so we can check.
Sebastien
Badge +11
Hi @Oracle ,
You can reset the password from the WebConsole login page;
You will need access to the email account associated to the Commvault account
