Restore Validate Workflow is not working properly on Aix/Linux system
  • 21 February 2024
  • 50 views
Badge +5
Hello All,
I am using restore validate workflow for restore tests. It worsk fine on windows clients. one Validate Restore job working then Restore validate job showing as restoring data. But When I triy it on Linux/aix cl,ients , It does not show validate restore job as like restoring.
Only validate restore job working but It does not show the client as restoring. does not it support for aix/linux? I have addes screnshots
Badge
Hi ,
This workflow only works for FS, SQL and VSA agent types. If linux client is in one of these agent types, it will work.
From the screenshot, I understood that, it didnt find any of these agent types in the given client group. Can you please confirm ?
Badge +5
Yes Im trying on linux and Aix clients. You can see from the screenshots. There is cleitn and its backup
Badge
Thanks for the confirmation. Linux AIX support was not added to this workflow, we will add it soon and update.
Badge +5
Hello
When will support AIX and linux  ? İs there any date ?
Badge
Should be available by end of next week.
Badge
Support for linux is added and updated workflow should be available in store by 03/11..
