Restore Validate Workflow is not working properly on Aix/Linux system
  • February 21, 2024
  • 109 views
Forum|alt.badge.img+9
Hello All,
I am using restore validate workflow for restore tests. It worsk fine on windows clients. one Validate Restore job working then Restore validate job showing as restoring data. But When I triy it on Linux/aix cl,ients , It does not show validate restore job as like restoring.
Only validate restore job working but It does not show the client as restoring. does not it support for aix/linux? I have addes screnshots
  • February 21, 2024
Hi ,
This workflow only works for FS, SQL and VSA agent types. If linux client is in one of these agent types, it will work.
From the screenshot, I understood that, it didnt find any of these agent types in the given client group. Can you please confirm ?
  • February 22, 2024
Yes Im trying on linux and Aix clients. You can see from the screenshots. There is cleitn and its backup
  • February 22, 2024
Thanks for the confirmation. Linux AIX support was not added to this workflow, we will add it soon and update.
  • February 22, 2024
Hello
When will support AIX and linux  ? İs there any date ?
  • February 23, 2024
Should be available by end of next week.
  • March 6, 2024
Support for linux is added and updated workflow should be available in store by 03/11..
