Scheduling a live mount restore and getting a report of it
  • May 19, 2023
  • 64 views
Forum|alt.badge.img+16
one of our client need test the one of the backup in every month to make sure that they have a working backup copy ,
is there anyway we can automate this process where each month end, it trigger a restore operation to using live mount and does the testing and delete it ,and send a report to team,
is it achievable using workflow , can anyone help how can i build
Best answer by SparshGupta
Hi @Ajal
This is not an easy effort, and perhaps couldn’t be explained over a single chat thread.
Can you open a ticket with support team, and they would be able to help you out if this is achievable after syncing up with appropriate team.
Sparsh
SparshGupta
  • May 19, 2023
Hi @Ajal
Sparsh
