Good evening all
I've never upgraded a Service Pack in a LiveSync configuration.
I know that you usually run the 'install updates' command on a secondary commserve with the 'do not update db' parameter.
In a LiveSync configuration, do you install the Service Pack on each commserve and treat it as the primary during the upgrade or install via command line and 'do not update db'?
Mauro
Best answer by Michael
