Is SQL 2019 Management studio plug-in supported?
Not mentioned in the BOL and plug-in registration does not work.
Rob
Best answer by Damian Andre
View originalHi,
Rob
View originalHi
Unfortunately the plugin does not yet support SSMS 19. It is targeted for a future release but not clear if its 11.32 or 11.34 at this time.
Thanks Damian!
Robert
Rob
11.32 has it, good news :)
