SQL 2019 Management studio Plug-in supported?
  • May 4, 2023
  • 355 views
Is SQL 2019 Management studio plug-in supported?
Not mentioned in the BOL and plug-in registration does not work.
Rob
Best answer by Damian Andre
Hi @RobsterFine,
Unfortunately the plugin does not yet support SSMS 19. It is targeted for a future release but not clear if its 11.32 or 11.34 at this time.
  • May 4, 2023
Hi @RobsterFine,
  • May 4, 2023
Thanks Damian!
Robert
  • March 13, 2024
Rob
11.32 has it, good news :)
