SQL backup failed: Another backup is running for client
  • May 12, 2022
  • 1032 views
HI Team,
we are getting below error when SQL job scheduler run
Description: Another backup is running for client [zucnlifdbmfoctn], iDataAgent [SQL Server], Instance [zucnlifdbmfoctn], Subclient [default].
Source: zucpgtssvcvcsm1, Process: JobManager
Best answer by Mike Struening
@kumar , is the job getting that error NOW or did it happen earlier (perhaps when other jobs were running)?
You can enable this option:
Control Panel > Job Management > General tab, select Queue jobs if other conflicting jobs are active
This will cause these jobs to queue up until the previous job(s) complete.
@kumar , check the job controller (filter by this client name) and see if another job for the same subclient is running.
the newer job will resume once the prior job completes.
  • May 12, 2022
I have check and there is no another job running only file level incremental backup is working fine rest all SQL job failed.
