hey
We recently upgraded the system to version 11.28.49 and something go wrong in sso
do u know what i can do about it??
Best answer by Chris Hollis
View originalhey
View originalHi
Mind sharing some extracts from the evmgrs.log on the Commserve?
Try login to replicate the failure, then open this log from log folder directory (default path - C:\Program Files\Commvault\Content Store\Log Files) and around about that time stamp we should get a bit more information on the failure.
Share the extracts here (after you mask anything sensitive).
Chris
