Considering that currently Commvault basically supports only infinity retention for o365 backup services, what will be the preferred / cost optimized choice of blob tier? As Disk Storage in a Azure MediaAgent.
Hot, Cool or Cold?
Please for your feedback, thoughts!
Best regards, Nikos
Page 1 / 1
Hi Nikos,
Cool would probably be best here.
While you could save even more money with straight Cold, you would have to contend with longer restore times (due to recalling).
Hi @Nikos.Kyrm
You can use cool storage for a secondary copy, but not for a primary copy:
So, except from minimum required days, is there any other differences between tiers? For example speed?
Hot tier - An online tier optimized for storing data that is accessed or modified frequently. The hot tier has the highest storage costs, but the lowest access costs. Cool tier - An online tier optimized for storing data that is infrequently accessed or modified. Data in the cool tier should be stored for a minimum of 30 days. The cool tier has lower storage costs and higher access costs compared to the hot tier. Cold tier - An online tier optimized for storing data that is rarely accessed or modified, but still requires fast retrieval. Data in the cold tier should be stored for a minimum of 90 days. The cold tier has lower storage costs and higher access costs compared to the cool tier.
@Nikos.Kyrm From my understanding the performance is similiar. All three have milliseconds latency while archive has hours due to rehydration. Hot has 99.9% availability while cool and cold has 99%
You need to beware of the increased cost of writes and reads of cool. I have not looked at cold, but prices for write/read would be higher from here.
If you store and read 1 TB from cool, Total cost is the same pr month as store and read 1 TB from Hot.
Aux copies/sfulls and restores will increase read and data retrival costs.
Hot gives you predictable costs, while cold can give you varying costs (potentially higher than hot). I assume this is the main reason for recommending primary copy on hot tier. Not a technical limitation.
