Azure Blob prefered tier for o365
  • 2 February 2024
  • 113 views
Userlevel 2
Badge +13
Hello all,
Considering that currently Commvault basically supports only infinity retention for o365 backup services, what will be the preferred / cost optimized choice of blob tier? As Disk Storage in a Azure MediaAgent.
Hot, Cool or Cold?
Please for your feedback, thoughts!
Best regards,
Nikos
Badge +4
Hi Nikos,
Cool would probably be best here.
While you could save even more money with straight Cold, you would have to contend with longer restore times (due to recalling).
Badge +6
Hi @Nikos.Kyrm
You can use cool storage for a secondary copy, but not for a primary copy:
https://documentation.commvault.com/2023e/essential/use_express_configuration_option_in_office_365_guided_setup_for_exchange_online.html
Hi @Nikos.Kyrm
I think this limitation only applies to Metallic Recovery Reserve / Air Gap protect rather than bringing your own storage.
Userlevel 2
Badge +13
Here are the pay-as-you-go prices, also with cold tier:
https://azure.microsoft.com/en-us/pricing/details/storage/blobs/
So, except from minimum required days, is there any other differences between tiers? For example speed?
Hot tier - An online tier optimized for storing data that is accessed or modified frequently. The hot tier has the highest storage costs, but the lowest access costs.
Cool tier - An online tier optimized for storing data that is infrequently accessed or modified. Data in the cool tier should be stored for a minimum of 30 days. The cool tier has lower storage costs and higher access costs compared to the hot tier.
Cold tier - An online tier optimized for storing data that is rarely accessed or modified, but still requires fast retrieval. Data in the cold tier should be stored for a minimum of 90 days. The cold tier has lower storage costs and higher access costs compared to the cool tier.
https://learn.microsoft.com/en-us/azure/storage/blobs/access-tiers-overview
Userlevel 1
Badge +7
@Nikos.Kyrm From my understanding the performance is similiar. All three have milliseconds latency while archive has hours due to rehydration. Hot has 99.9% availability while cool and cold has 99%
You need to beware of the increased cost of writes and reads of cool. I have not looked at cold, but prices for write/read would be higher from here.
If you store and read 1 TB from cool, Total cost is the same pr month as store and read 1 TB from Hot.
Aux copies/sfulls and restores will increase read and data retrival costs.
Hot gives you predictable costs, while cold can give you varying costs (potentially higher than hot). I assume this is the main reason for recommending primary copy on hot tier. Not a technical limitation.
