Remote VM backups - can a remote proxy dedupe across the WAN?
  • 6 October 2021
  • 193 views
Userlevel 1
Badge +4
Is this possible or any better ideas?
Problem: Remote office with a small VMware setup where CV agents on clients not permitted.  If agents could be installed it would be a simple case of client-side deduplication so they could be backed up remotely.
To get deduplication happening would it possible to use a VM-proxy at the remote site send backup data to the data center?
The idea would be:
Remote ESX → Remote Proxy …..can’t be deduped because no agent to do it
Remote Proxy → data center media agent ….deduped on the proxy
Restore will be obviously fully hydrated...they are prepared to live with.
Best answer by YYZ 6 October 2021, 11:57
Badge +12
Hi JM
This should hopefully answer your question
Userlevel 1
Badge +4
Thanks for that ..I’ll give it go in couple of weeks
