Remote VM backups - can a remote proxy dedupe across the WAN?
  • October 6, 2021
  • 249 views
Is this possible or any better ideas?
Problem: Remote office with a small VMware setup where CV agents on clients not permitted.  If agents could be installed it would be a simple case of client-side deduplication so they could be backed up remotely.
To get deduplication happening would it possible to use a VM-proxy at the remote site send backup data to the data center?
The idea would be:
Remote ESX → Remote Proxy …..can’t be deduped because no agent to do it
Remote Proxy → data center media agent ….deduped on the proxy
Restore will be obviously fully hydrated...they are prepared to live with.
Best answer by YYZ
Hi JM
This should hopefully answer your question
YYZ
Challenger
  • Challenger
  • October 6, 2021
Hi JM
  • October 7, 2021
Thanks for that ..I’ll give it go in couple of weeks
