We have a customer who uses commvault mail archive system and when they try to use outlook addin they says it was be crush the outlook session , and when they try to download archived e mail thay took a certificate problems . Is commvault have a updated new add in of this solition or how we can fix theese problems
Hi
For which version?
Sebastien
+1
Commvault Version 11.28.72
Addin Version 11.30.63
Not aware of any issues, last one was fixed in 30.38
Are you able to log a case with Support?
+1
Yes we have a support
