Commvault Outlook Add In Crashs outlook session
  • Nov 13, 2023 10:46 AM UTC
  • 93 views
Forum|alt.badge.img+2
We have a customer who uses commvault mail archive system and when they try to use outlook addin they says it was be crush the outlook session , and when they try to download archived e mail thay took a certificate problems . Is commvault have a updated new add in of this solition or how we can fix theese problems
Best answer by Sebastien Merluzzi
Not aware of any issues, last one was fixed in 30.38
Are you able to log a case with Support?
Hi @Burak Kosker ,
For which version?
Sebastien
  • Nov 13, 2023 11:12 AM UTC
Commvault Version 11.28.72
Addin Version 11.30.63
  • Nov 13, 2023 12:43 PM UTC
Yes we have a support
