We have a customer who uses commvault mail archive system and when they try to use outlook addin they says it was be crush the outlook session , and when they try to download archived e mail thay took a certificate problems . Is commvault have a updated new add in of this solition or how we can fix theese problems
Commvault Outlook Add In Crashs outlook session
Hi
For which version?
Sebastien
![Contributor 1 Badge](https://uploads-eu-west-1.insided.com/commvault-eu/attachment/4829f3c4-ae47-49ea-be52-8a8643d02f44_thumb.png)
Commvault Version 11.28.72
Addin Version 11.30.63
Not aware of any issues, last one was fixed in 30.38
Are you able to log a case with Support?
Yes we have a support
