Commvault Outlook Add In Crashs outlook session
  • November 13, 2023
  • 93 views
Forum|alt.badge.img+2
We have a customer who uses commvault mail archive system and when they try to use outlook addin they says it was be crush the outlook session , and when they try to download archived e mail thay took a certificate problems . Is commvault have a updated new add in of this solition or how we can fix theese problems
Best answer by Sebastien Merluzzi
Not aware of any issues, last one was fixed in 30.38
Are you able to log a case with Support?
Hi @Burak Kosker ,
For which version?
Sebastien
  • November 13, 2023
Commvault Version 11.28.72
Addin Version 11.30.63
  • November 13, 2023
Yes we have a support
