How to take backup job with minimum 5 copies or 2 copies?
  • 14 March 2024
  • 47 views
Badge +5
My actual question is , if  we want take bakup job of secondary copy or multiple copy. ?
how to configure or process ?
how many maximum backup copy job can take ?
Best answer by Sebastien Merluzzi 14 March 2024, 13:09
Badge +14
HI @Keshav Sawant ,
You can check our documentation below:
https://documentation.commvault.com/2023e/expert/additional_copies_of_backup_data.html
There is no limit. You are only limited by the amount of disk I/O, number of media agents, number of concurrent operations set on those media agents, number of streams available to the storage policies
Sebastien
Userlevel 1
Badge +4
Hi Keshav
For most backups (not M365) you can add a second copy from the Pan-Backup Destinations.
https://docs.metallic.io/metallic/modifying_server_plan_in_advanced_view.html
Some auto generated plans may not have this option if they were created with a single copy.  Please reach out to a CSM for assistance with this.
The number of copies is limited by default to 2, if more copies are needed please discuss this with your CSM.
Regards
Andy
Badge +5
how to create backup copy schedule policy and auxiliary copy schedule policy ?
i tried to create but didn’t reflected destination or target.
Badge +14
Once created you just need to right clight on the Copy > View > Schedules
or go to Schedule Policies:
https://documentation.commvault.com/2023e/expert/auxiliary_copy_schedules.html
Or you can log a case with Support and we will check and configure with you.
Userlevel 1
Badge +4
Please note that this thread is for SAAS/Metallic workloads.
I did not realise you were looking at Commvault Core product.
If you are using Metallic and need to create a second storage location please check the following guides.
https://docs.metallic.io/metallic/cloud_storage.html
https://docs.metallic.io/metallic/configuring_cloud_storage.html
The Secondary copy is set to run automatically every 30 minutes by default.  This can be edited from the Plan RPO:
Andy
