My actual question is , if we want take bakup job of secondary copy or multiple copy. ?
how to configure or process ?
how many maximum backup copy job can take ?
Best answer by Sebastien Merluzzi
View originalMy actual question is , if we want take bakup job of secondary copy or multiple copy. ?
View originalHI
You can check our documentation below:
https://documentation.commvault.com/2023e/expert/additional_copies_of_backup_data.html
There is no limit. You are only limited by the amount of disk I/O, number of media agents, number of concurrent operations set on those media agents, number of streams available to the storage policies
Sebastien
Hi Keshav
For most backups (not M365) you can add a second copy from the Pan-Backup Destinations.
https://docs.metallic.io/metallic/modifying_server_plan_in_advanced_view.html
Some auto generated plans may not have this option if they were created with a single copy. Please reach out to a CSM for assistance with this.
The number of copies is limited by default to 2, if more copies are needed please discuss this with your CSM.
Regards
Andy
how to create backup copy schedule policy and auxiliary copy schedule policy ?
i tried to create but didn’t reflected destination or target.
Once created you just need to right clight on the Copy > View > Schedules
or go to Schedule Policies:
https://documentation.commvault.com/2023e/expert/auxiliary_copy_schedules.html
Or you can log a case with Support and we will check and configure with you.
Please note that this thread is for SAAS/Metallic workloads.
I did not realise you were looking at Commvault Core product.
If you are using Metallic and need to create a second storage location please check the following guides.
https://docs.metallic.io/metallic/cloud_storage.html
https://docs.metallic.io/metallic/configuring_cloud_storage.html
The Secondary copy is set to run automatically every 30 minutes by default. This can be edited from the Plan RPO:
Andy
