Is there a way to prevent these automatic updates to the Media Agents from running?
Version 11.2801.22 breaks VMware backups and I have to keep manually reverting to 11.2801.11. Very frustrating!
On Metallic? How do I access the console?
You can’t access this console when you are using Metallic. Have you checked out the Metallic documentation? If you are hitting an issue with the MAs than I would open a ticket to get it sorted!
Well Metallic’s down at the moment, for a change.
But I did log a Critical over 3 hours ago, no response as yet.
Ok, we’ll in that case it might be that they are installing a maintenance release that also addresses your issue. So I would recommend to see if this this is the case once it is back online and see what happens once you update your MAs.
It’s possible, but it’s not in “Maintenance”, jobs are just Waiting and some pages don’t load. Call logged for that too.
Going to have some pretty unhappy customers when their TLog drives fill up.
Will do, thanks.
I’ll move this to the Metallic Q&A section so it gets better attention and tracking.
You can check in device manager at MA / proxy under SCSI if Commvault driver is enabled. But there could be dozen of other root causes.
Tbh, support is.. average.. and everything takes ages..
If that sounds good to you, can you send me a pm with some details on the case numbers and what could have been done better?
Hi Mike, can I please ask you to get involved here, it seems my message is not getting through.
220713-177
I’ve tried to explain that on version 11.2801.11 all is well, but on versions 11.2801.22 and 11.2801.23 vsbkp.exe sometimes crashes and the job fails. Different days, different Gateways. But I am banging my head against a brick wall.
Many thanks,
So the issue remains…..
I downgraded this morning to .11 and before I could rerun the failed jobs it auto-updated to .23.
Pulling my hair out here.
What do you see when you lookup the job history on server level? Do not forget to select show admin jobs. It really appears they have a backend job running that constantly runs and performs forced updates on clients running the MA role.
Hi Shane
Looking at the thread and case I can see Development backported a fix.
The fix is to stop invoking APIs on VDDK versions lower than 6.5.2
So the best path forward is that we get the environment on 11.2801.22
Crash dumps have been enabled so if there is an issue then we can get the dumps and logs to Dev and confirm if the API’s is not being invoked and it could be something else that the team need to help you resolve.
Hi Shane
I have uploaded 2 or 3 of these process dumps on the ticket.
Hi Shane
Thanks for the dumps it was appreciated. Those dumps were used to help identify that the API was causing the issues.
As per the engineer’s findings lets get everything on the same version and then we can monitor and make sure the jobs are running successfully.
If any jobs fail then notify the engineer of the time frame and they can help you and diagnose the logging.
Hi Shane
Thanks Ryan
I’ve updated all the gateways, will monitor and advise.
It’s part of a schedule, yes. Otherwise they wouldn’t get the right updates on time (consistently).
All jobs went well last night, except for one unrelated failure, so far so good!
Good to hear Shane
I’ve notified the engineer assigned to the ticket to let him know.
As Mike mentioned the Gateways get updated as part of a weekly schedule. This includes critical patches such as the one we had from your site with the API so other customers don't get affected.
But again, glad to see the jobs are going through successfully.
let me know if you need anything further on this thread.
Ryan
