Oracle backup faling with Another backup job is running for client iDataAgent [Oracle RAC]
  • May 17, 2024 6:23 PM UTC
  • 329 views
Error code: [19:2586]
Description: Another backup job [52212350] is running for client, iDataAgent [Oracle RAC], Backup Set [defaultBackupSet], Subclient [default].
Source: cms01101c1us07, Process: JobManager
Forum|alt.badge.img+13
@Raj L
There is a another job running for the same sub-client. You can check the same under Jobs>Active jobs.
Please wait till the jobs gets completed and then start the new one.
Lukas3D
Explorer
  • May 20, 2024 6:32 AM UTC
Most likely job is triggered twice for the same scope, so the second one is failed/skipped or the new one is triggered before previous was completed.
