I’m trying to restore data from tape and when it attempts to restore the Index I receive the following errors:
- Error: Unable to find/get index in the cache for [SubClient_81] at time [Fri May 5 14:14:14 2023].
- Backup data browse in subclient [1032011_SERVERNAME\Windows File System\BackupSet_1032011_33_45\Subclient_81] not completed due to failed index cache restore.
- Media with barcode [ARM960L7]. side [A_1125], mounted on library [IBM 3573-TL 16] and drive [IBM ULT3580-HH7_1] on MediaAgent [SERVERNAME]. Mountpoint [\\.\Tape0] for job [313813]. Media block size is [64k]. Mount finished in [39] seconds
I can see the tape that contains the Index is mounted into the Tape Drive and from there when it attempts to restore the Index I receive the following errors above.
Has anyone seen this issue before?
Thanks all
