Attempting to restore an Index from Tape Backups fails
  • July 10, 2023
  • 7 replies
  • 548 views
Forum|alt.badge.img+2
I’m trying to restore data from tape and when it attempts to restore the Index I receive the following errors:
  • Error: Unable to find/get index in the cache for [SubClient_81] at time [Fri May 5 14:14:14 2023].
  • Backup data browse in subclient [1032011_SERVERNAME\Windows File System\BackupSet_1032011_33_45\Subclient_81] not completed due to failed index cache restore.
  • Media with barcode [ARM960L7]. side [A_1125], mounted on library [IBM 3573-TL 16] and drive [IBM ULT3580-HH7_1] on MediaAgent [SERVERNAME]. Mountpoint [\\.\Tape0] for job [313813].  Media block size is [64k].  Mount finished in [39] seconds
I can see the tape that contains the Index is mounted into the Tape Drive and from there when it attempts to restore the Index I receive the following errors above.
Has anyone seen this issue before?
Thanks all
Best answer by LeeCooperSaab
Hi @Damian Andre ,
I also raised a ticket with Commvault and they have reviewed more of our logs and advised there may be a communication drop between the MA and CS.  They have requested we create a persistent tunnel between to the servers to see if this resolves the issue.
I’ll let everyone know if this fixes it.  Thanks for the comments.
Rajiv
  • July 10, 2023
Hello @LeeCooperSaab
Could you please check if the backup you are trying to recover has the retention or its expired?
Best,
Rajiv Singal
IndexState.log on the MediaAgent might reveal more information.
Thank you,
Collin
Hi @Rajiv
I’ve checked all the backups that reside on these tapes and the retention across all of them are set to Infinite.
Thanks for the suggestion
Hi @Collin Harper
I checked the IndexState.log file and there are no events during the time I attempted to restore data from those tapes.
The last logs I see are from 4 days ago stating the following:
  • Status [IDX_DB_RECONSTRUCTION] - ReconJobcount [1]
  • Status [IDX_DB_SUCCESS]
Are there other logs I can check?
Sounds like it may be an indexing V1 job - you could check indexrestore.log on the Media Agent, as one of the errors says it was not able to restore the index.
  • July 13, 2023
Hi @Damian Andre ,
Hi @Damian Andre ,
Sounds good! lets see how you go.
