Azure Data box disk for copy data.
  • April 18, 2023
  • 272 views
Michal128
Explorer
Forum|alt.badge.img+9
Today we would like to order some external device from Azure to copy the data between Azure and local site.
Azure provide two options:
-Azure Data Box Disk
-Azure Data Box.
According to documentation Commvault support the second option, link to documentation:
https://documentation.commvault.com/v11/expert/97276_migrating_data_to_microsoft_azure_using_azure_data_box.html
but how does it look for the first option. We have network connection built on 1 Gb/s which should be so slow to send 30 TB of data. So maybe better option is Azure Data Box disk which can be connected by USB slot.
Michal
Best answer by Michal128
Hello Community,
I checked the possibility for both solutions. In my option Storage Data Box Disk is completely unuseful. Few thinks:
  1. Storage is divided on 5 separated disks.
  2. Payment started from beginning when  usage that solution lunched.
  3. Supported OS which can use that solution is only until Windows Server 2016.
So from my used study please use only Azure data box, or Azure Data Box Heavy.
Michal
Emils
  • April 24, 2023
Hi @Michal128
Thank you for reaching out.
I do believe both would be supported as both would be seen as a disk library in Commvault.
I will get this verified and update the document accordingly.
Michal128
Explorer
  • May 31, 2023
Hello Community,
Michal
Nikos.Kyrm
Forum|alt.badge.img+16
  • Community All Star
  • July 8, 2024
Hello @Michal128 ,
Any feedback about Azure Data Box? Did you used the service?
I try to understand how you are going to “see” the Disk Library in the Data box, in order to proceed with aux copy.
Nikos
Michal128
Explorer
  • July 8, 2024
Hello NIkos.
The Azure Data Box is visible from the Commvault Commcell as NAS storage. From my site I see that only useful is Azure Data Box and Azure Data Box Heavy. We ordered the Azure data Disks, but this feature is not useful completely, because that hardware is delivered are separated disks, so if You have 5 TB of data only maybe that solution can be use, but for another only Azure Data Box or Heavy type.
Michal
