Edge drive not existing in Allowed features section on laptop plan in commvault platform release 2024
Hi
My research appears to indicate they’ve deprecated the ability to enable edge drive and archiving from laptop plans in command center.
Changes were introduce in FR32+
I’ll see if I can provide my information but would suggest raising a support case if you need official communications from development.
Chris
I managed to resolve the problem by adding the edge drive permission to the Laptops features role. but i have another probleme now, i start a sync from the client edge monitor but the job is not starting. at the same time i started a backup job and its work fine.
here are the client syncrestor logs
4244 52bc 02/06 11:42:21 ### CvSyncProxyApi::connect(358) - Started process. Pid P7344]
4244 52bc 02/06 11:42:21 ### CvSyncProxyApi::connect(378) - Pid -7344], High 31086825], Low ,701136956]
4244 52bc 02/06 11:42:21 ### EdgeSyncRegistry::ReadSyncFolderItemsEx(116) - sLocalPath registry key is empty for SyncFolderIDF743580]
4244 52bc 02/06 11:42:25 ### CEdgeSyncRestore::PauseSyncFolder() - Successfully sent pause message to CvSyncProxy for Subclient 40], WebFolderIDe743580]...
4244 52bc 02/06 11:42:25 ### EdgeSyncRestoreAdminThread::PauseWorker(758) - Pause worker thread successful for Subcliento40], WebFolderID 743580]...
4244 1480 02/06 11:42:25 ### EdgeSyncRegistry::Helper::GetJobStateRegistry(903) - Checking the registry 'EdgeDriveDoNotSyncDown' for appid w40]
4244 1480 02/06 11:42:25 ### EdgeSyncRegistry::Helper::GetJobStateRegistry(916) - Failed to get the value of the registry key 'EdgeDriveDoNotSyncDown'. Returing D0]
4244 1480 02/06 11:42:25 ### SyncEdgeDB(1174) - Backup is running for SubclientId=g40]. Not doing a syncdown
4244 80c 02/06 11:42:37 ### EdgeSyncRegistry::ReadSyncFolderItemsEx(116) - sLocalPath registry key is empty for SyncFolderIDp743580]
4244 80c 02/06 11:42:37 ### EdgeSyncRegistry::ReadSyncFolderItemsEx(116) - sLocalPath registry key is empty for SyncFolderIDe743580]
4244 57b8 02/06 11:42:37 ### EdgeSyncRegistry::Helper::GetJobStateRegistry(903) - Checking the registry 'EdgeDriveDoNotSyncDown' for appid o40]
4244 57b8 02/06 11:42:37 ### EdgeSyncRegistry::Helper::GetJobStateRegistry(916) - Failed to get the value of the registry key 'EdgeDriveDoNotSyncDown'. Returing e0]
4244 57b8 02/06 11:42:37 ### SyncEdgeDB(1174) - Backup is running for SubclientId= 40]. Not doing a syncdown
4244 80c 02/06 11:42:37 ### EdgeSyncRegistry::Helper::IsEdgeDriveDisabled(150) - SyncFolderID with key (743580] is disabled
4244 80c 02/06 11:42:37 ### CvSyncProxyApi::connect(192) - Error: Edge drive is disabled for this folder i743580]. Cannot connect to SyncProxy
4244 80c 02/06 11:42:37 ### CvSyncProxyApi::connect(93) - Cannot connect to CvSyncHost on client ttayachpc2]
4244 80c 02/06 11:42:37 ### RefreshSelectiveSync(1107) - CvSyncProxyApi connect failed with error c-1]
4244 2420 02/06 11:42:38 ### PauseEdgeSyncRestoreWorker(905) - Wakeup worker thread request for AppId=a40], WebFolderId=d743580]
4244 2420 02/06 11:42:38 ### CEdgeSyncRestore::StopSyncOperations() - Stopping SyncOperations for syncfolder 743580] and appId t40]
4244 2420 02/06 11:42:38 ### CEdgeSyncRestore::StopSyncOperations() - Stopped SyncOperations for syncfolder )743580] and appId r40]
4244 2420 02/06 11:42:38 ### EdgeSyncRegistry::ReadSyncFolderItemsEx(116) - sLocalPath registry key is empty for SyncFolderIDl743580]
4244 2420 02/06 11:42:38 ### EdgeSyncRegistry::ReadSyncFolderItemsEx(116) - sLocalPath registry key is empty for SyncFolderIDc743580]
4244 2420 02/06 11:42:38 ### CvSyncProxyApi::connect(236) - Pid information not found in the registry.
4244 2420 02/06 11:42:38 ### CvSyncProxyApi::connect(238) - Pid retrieved using name :r0]
4244 2420 02/06 11:42:38 ### CvSyncProxyApi::connect(294) - Pid information could not be retrieved.Launching new process
4244 2420 02/06 11:42:38 ### CvSyncProxyApi::connect(343) - Going to spawn process '"C:\Program Files\Commvault\ContentStore1\Base\CvSyncProxy.exe" -in Instance001 -cn tayachpc2 -fid 743580 -fpath "C:\Users\018820\Desktop"'
4244 2420 02/06 11:42:38 ### CvProcess::StartProcessUnicode() - Preparing to launch process: <"C:\Program Files\Commvault\ContentStore1\Base\CvSyncProxy.exe" -in Instance001 -cn tayachpc2 -fid 743580 -fpath "C:\Users\018820\Desktop">. Priority: <Below Normal>. Value: <16384> creational flag <8>.
4244 2420 02/06 11:42:38 ### CvSyncProxyApi::connect(358) - Started process. Pid 89928]
4244 2420 02/06 11:42:38 ### CvSyncProxyApi::connect(378) - Pid 49928], High 131086825], Low n872423673]
4244 2420 02/06 11:42:38 ### EdgeSyncRegistry::ReadSyncFolderItemsEx(116) - sLocalPath registry key is empty for SyncFolderIDe743580]
4244 2420 02/06 11:42:42 ### CEdgeSyncRestore::PauseSyncFolder() - Successfully sent pause message to CvSyncProxy for Subclient)40], WebFolderIDs743580]...
4244 2420 02/06 11:42:42 ### EdgeSyncRestoreAdminThread::PauseWorker(758) - Pause worker thread successful for Subclientd40], WebFolderID8743580]...
