Data Priavacy feature - alert or report for affected clients?
  • 14 December 2021
  • 17 views
Guys,
Is there a report or alert to check daily basis if privacy option still remain disable and send to an mail to us ?
Anyone has any idea or suggestions ?
@0ber0n can you clarify a bit?  Are you looking for an alert for any client when this feature is disabled?  Or a report to see which clients have it disabled?
What’s your end goal?  to see which are disabled, then enable it across?
I’m going to split this into its own thread to track an answer better.
Hi Mike,
Actually, a report would be good. I want to report which clients are disabled on a daily basis.
Apologies for the delay; I am not seeing any report available.  If you create a support case, they can request a CMR from dev for you (or look into custom reporting options, though they can’t build the report itself).
Keep me posted on the case number.
Hi Mike,
Thanks for the reply.
I opened a case: 220106-254
Thanks!!
