Data Priavacy feature - alert or report for affected clients?
  • December 14, 2021
  • 30 views
Forum|alt.badge.img+13
Guys,
Is there a report or alert to check daily basis if privacy option still remain disable and send to an mail to us ?
  • December 27, 2021
Anyone has any idea or suggestions ?
@0ber0n can you clarify a bit?  Are you looking for an alert for any client when this feature is disabled?  Or a report to see which clients have it disabled?
What’s your end goal?  to see which are disabled, then enable it across?
I’m going to split this into its own thread to track an answer better.
  • January 5, 2022
Hi Mike,
Actually, a report would be good. I want to report which clients are disabled on a daily basis.
Apologies for the delay; I am not seeing any report available.  If you create a support case, they can request a CMR from dev for you (or look into custom reporting options, though they can’t build the report itself).
Keep me posted on the case number.
  • January 13, 2022
Hi Mike,
Thanks for the reply.
I opened a case: 220106-254
Thanks!!
