Has anyone inquired if Commvault will be affected by this once to security is fully put in place on March 2023?
Best answer by DMCVault
View originalHas anyone inquired if Commvault will be affected by this once to security is fully put in place on March 2023?
View originalI’ll check with
From MSFT:
https://msrc.microsoft.com/update-guide/vulnerability/CVE-2021-26414
I can’t find anything showing we are affected, though there’s a remediation available.
Yes please do
I agree with that it probably will not affect CV but wanted to make sure.
Thank you
I recently had to disable the hardening in order to install CV agents onto a Hyper-V host from the CommServe. With hardening enabled on other hosts, I had to copy the packages to the host and run CV setup locally.
Not being able to remotely push out client installs from CV isn’t great.
So I think there is an impact, though perhaps additional testing / understanding is required.
Personally, I”m going to engage my local CV team and log a case to investigate this further.
