DCOM Hardening CVE-2021-26414
  • July 1, 2022
  • 7 replies
  • 447 views
Has anyone inquired if Commvault will be affected by this once to security is fully put in place on March 2023?
Best answer by DMCVault
@ShaneHicks I dug into it, and found that we had recently tested this MS fix, and confirmed no impact on Commvault.  Let us know if you have further questions.
@ShaneHicks , I’m not seeing anything in our docs or incidents.
I’ll check with @DMCVault who would know.
@ShaneHicks , I talked to @DMCVault who mentioned the fix for this is to apply Windows updates.
From MSFT:
https://msrc.microsoft.com/update-guide/vulnerability/CVE-2021-26414
I can’t find anything showing we are affected, though there’s a remediation available.
  • July 1, 2022
@ShaneHicks  we dont think this will have any effects on our software, but we will validate just to be sure.
  • July 1, 2022
Yes please do @DMCVault . We just want to make sure that in March 2023 when the component is not available anymore that Commvault will be ok.
I agree with that it probably will not affect CV but wanted to make sure.
  • July 5, 2022
  • July 6, 2022
Thank you @DMCVault for your help.
  • August 19, 2022
I recently had to disable the hardening in order to install CV agents onto a Hyper-V host from the CommServe. With hardening enabled on other hosts, I had to copy the packages to the host and run CV setup locally.
Not being able to remotely push out client installs from CV isn’t great.
So I think there is an impact, though perhaps additional testing / understanding is required.
https://support.microsoft.com/en-us/topic/kb5004442-manage-changes-for-windows-dcom-server-security-feature-bypass-cve-2021-26414-f1400b52-c141-43d2-941e-37ed901c769c
Personally, I”m going to engage my local CV team and log a case to investigate this further.
