Anyone know how to migrate/convert SP to Plan?
Hi
You will have to follow the doc link below and run a workflow for conversion.
https://documentation.commvault.com/2023e/essential/converting_storage_policies_to_server_plans.html
Thanks.
Here’s some additional points. These are also shared on a similar thread.
1. What benefits would there be to perform the switch from policies to plans other than it is just one configuration point instead of two?
- Can have content and schedules for backups in Plans
- Region-Based Storage for Laptop and Server Plans
https://documentation.commvault.com/2023e/essential/region_based_storage_for_laptop_and_server_plans.html
2. Are there some crucial benefits which we are not aware of?
- Starting with platform release 2024 (11.34), new deployments using this version will no longer have access to the CommCell interface, even if current users can continue to use it, hence it is preferable to begin moving to Command Centre.
3. Could you give us some pros and cons since you are recommending to think about switching to plans?
- Cons - Cannot think of any
- Effects of Converting Storage Policies to Plans
https://documentation.commvault.com/2023e/essential/effects_of_converting_storage_policies_to_plans.html
