Hi all
someone doing comvault monitoring with zabbix by agent?
if so please help us at the config level
best regards
View originalHi all
best regards
View originalHi
There are other posts who were raised in the past related to Zabbix like:
Not sure where you are thinking to start with when it comes to Zabbix. Can you elaborate what you want to achieve?
Onno
Thanks for your feedback
I have already installed zabbix agent on commserve server and everything is good
but I did not find any template to integrate it, for example the controllers of the teches... the state of the backups..
It is also possible to monitor via API. Zabbix is very good at keeping an eye on your backups, libraries availability and space consumption. Commvault has quite an extensive API, you can create a lot of interesting solutions on it. Unfortunately, there is no template, so you have to create it yourself.
