monitor commvault by zabbix
  • August 25, 2022
  • 2000 views
Hi all
someone doing comvault monitoring with zabbix by agent?
if so please help us at the config level
best regards
Hi @aref,
There are other posts who were raised in the past related to Zabbix like:
Not sure where you are thinking to start with when it comes to Zabbix. Can you elaborate what you want to achieve?
Onno
Onno van den Berg
Forum|alt.badge.img+24
Hi @aref,
Onno
  • August 25, 2022
Thanks for your feedback @Onno van den Berg
I have already installed zabbix agent on commserve server and everything is good
but I did not find any template to integrate it, for example the controllers of the teches... the state of the backups..
  • November 7, 2022
It is also possible to monitor via API. Zabbix is ​​very good at keeping an eye on your backups, libraries availability and space consumption. Commvault has quite an extensive API, you can create a lot of interesting solutions on it. Unfortunately, there is no template, so you have to create it yourself.
