monitor commvault by zabbix
  • August 25, 2022
  • 1284 views
Hi all
someone doing comvault monitoring with zabbix by agent?
if so please help us at the config level
best regards
Hi @aref,
There are other posts who were raised in the past related to Zabbix like:
https://community.commvault.com/commvault-q-a-2/monitor-commvault-with-zabbix-by-agent-3529
Not sure where you are thinking to start with when it comes to Zabbix. Can you elaborate what you want to achieve?
Onno
Onno van den Berg
Commvault Certified Expert
Forum|alt.badge.img+20
Hi @aref,
Onno
  • Bit
  • August 25, 2022
Thanks for your feedback @Onno van den Berg
I have already installed zabbix agent on commserve server and everything is good
but I did not find any template to integrate it, for example the controllers of the teches... the state of the backups..
  • Bit
  • November 7, 2022
It is also possible to monitor via API. Zabbix is ​​very good at keeping an eye on your backups, libraries availability and space consumption. Commvault has quite an extensive API, you can create a lot of interesting solutions on it. Unfortunately, there is no template, so you have to create it yourself.
Cookie policy
Cookie settings
