We have problem with backing up Oracle database via RMAN on Linux server.
CommVault version is 11.20.9. When we kick off backup from RMAN it fails with these errors:
RMAN error:
RMAN-00571: ===========================================================
RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS ===============
RMAN-03009: failure of backup command on ch1 channel at 02/03/2021 20:55:06
ORA-19506: failed to create sequential file, name="1024672_PPRFLPU_7bvm9l7h_235_1_1", parms=""
ORA-27028: skgfqcre: sbtbackup returned error
ORA-19511: non RMAN, but media manager or vendor specific failure, error text:
CreateOraObject20: Job[1024672] thread[29473]: Connection with ClOraAgent failed(180 secs) for channel=1.
/var/log/commvault/Log_Files/ORASBT.log:
29473 7321 02/03 20:54:59 1024672 ::ConnectWithClOraAgent() - Attach_RemoteService to connect to ClOraClient failed with error [0x80
070306:{CCvNetwork::Attach_RemoteService(1691)} + {CCvNetwork::Attach_RemoteService(1654)} + {CCvNetwork::LookupRegisteredPorts(4697
)} + {CCvNetwork::LookupRegisteredPorts_Common(4822)} + {CCvNetwork::LookupRegisteredPorts_Common(4789)} + {CCvNetwork::LookupRegist
eredPorts_Local(4456)} + {CSessionConnectionSocket::LookupPort(1093)/W32.774.(One or more errors occurred while processing the reque
st. (ERROR_ERRORS_ENCOUNTERED.774))- No port looked up for service OraSbtSrvcData1024672_1}] for channel=1
There seems to be a Port configuration issue on servername server.
Fireweall is off on Linux server. When i run backup from CommCell for given subclient it finishes successfully.
We also have file agent installed to back up Linux OS and its also working OK.
Tried looking at this error but did not find much: "No port looked up for service OraSbtSrvcData".
Anyone had similar problem maybe?
Best answer by Gowri Shankar
