Is there a schedule policy for restoration?
Best answer by Navneet Singh
View originalIs there a schedule policy for restoration?
View originalFrom the schedule policy there is no option but you can try the below if this helps:
Hi
What agent are you looking for?
If the intention is to schedule restore, you can consider exploring periodic / continuous replication options as well.
https://documentation.commvault.com/11.24/essential/113647_disaster_recovery_and_replication.html
Sparsh
Currently you cannot do this from Command Center, however I do know it is expected to arrive soon for databases.
Hi Guys appreciate your responses. Will try first the schedule option upon the restoration process and see if this will work for me. Thank you!
