Copy hotfixes is skipped because the media is not available for it.
  • 10 May 2021
  • 7 replies
  • 1015 views
Badge +14
I am trying to copy maintenance release to software cache but I have this error message.
Copy hotfixes is skipped for [C:\Users\commvault\Downloads\Commvault_Maintenance_11_22_22_linux-x8664.tar] because the media is not available for it.
I have copied the windows package without any issue.
Also do you know where I can find all commvault error codes ?
Thanks !
Best answer by dude 10 May 2021, 20:08
Badge +9
Hi @Bloopa
Please check the following,
https://documentation.commvault.com/commvault/v11/article?p=106619.htm
  • You may run into issues when attempting to use the .tar
Kind Regards,
Sean
Badge +14
@Sean Crifasi Thank you for your very quick answer
I have untar the file but now I have
Error Code: [68:481] Description: The source folder [C:\Users\commvault\Downloads\Commvault_Maintenance_11_22_22_linux-x8664] is empty or doesn't have any valid Commvault media. Source: pcpo99a00c, Process: DownloadSoftware
It is strange because the folder seems to be good
Badge +15
@Bloopa
Can you try to place the file on the C:\temp\ if a temp does not exist create one.
Would be like
C:\temp\Commvault_Maintenance_11_22_22_linux-x8664.tar and then try to copy that again.
Badge +3
how did you solve this problem?
Badge
Did it resolve the issue?
Badge +3
my problem was solved when i tried to download and copy the whole package.
I split the new reply into its own thread here:
