What is the default retention when Commvault ask aws to take snapshot ?
I think that they’re deleted by commvault after a period but when ?
Thank you !
Best answer by Santhosh Ranga
View originalHello,
Thank you !
View originalI`m not sure I`m following the correct path here to answer your question, but my understanding is that the retention policy is set at the storage policy level and so whatever storage policy you are using to snap, that is where you should check the retention policy. It could be days, days+cycles etc etc.
Commvault will indeed delete the snapshots based on your retention.
