Problem in a Backup Job:
Does Someone know about this problem?
When the job started manually is OK, but when schedule dont run.
The backup job log file in attach.
View originalHello,
View originalLet me know the case number once you do!
Let me know if you get a CV incident number (that is likely a partner case number). I can search on the partner case number but only if it was supplied to us and entered :-(
Have you checked the Log Manager and IndexState logs on the MA at the times of the failure?
- check for the following GUID in those and let us know the results: DF8299F8-FFCF-434A-A722-87C1ABF09530
Michael
Thanks!!
Thanks!!
