Management has provided me with a separate partition for my Database backup jobs. I already have a storage policy dedicate to our DB backups. Is there a way to force a backup job or a storage policy to only save to a specified mount path? I am thinking I can move a mount path to the DB partition and then direct my DB storage policy or DB jobs to copy only to the mount path on the DB partition that has been provided
Can I point a specific backup job or storage policy to a specific mount path?
Best answer by Laurent
Hi and welcome !
Do you know if the mount path where your current ‘database’ backups are backup to, also contains backups from other storage policies, or is it already dedicated to database backups ?
Maybe the mount path is on a volume that hosts another mount path used for other storage policies. This we don’t know.
Because, if that’s the case, then performing a move of mount path can also be a solution : you’ll keep all backups and expiration dates, and no problem (though depends on the amount of data you have to move, and time it would take).
But if that mount path is also used to store backups of other storage policies (non sql, if I got your information), then move of mount path is not the solution, as it would move the whole contents = meaning all data from all the storage policies using that point path. ==> that’s where solutions provided by Emils and Mike would have to be applied.
