cant backup sap hana
  • June 19, 2022
  • 121 views
Hello All ,
I need help  , in deffault content the bdd are on line , but i cant see a tables
and i  have this error when backup
thank yous in advance
Cordialy
Adlene.
Best answer by Sunil
Hi @Adlene
We don’t support table level backup. I don’t see a way from SAP docs too. So, at this point you can only see and backup from database level.
Sunil-
Sunil
Forum|alt.badge.img+13
  • June 20, 2022
Hi @Adlene
We don’t see the tables in the content screen as the backup is at the database level. This is expected.
Coming to the error you’re noticing, this is usually a transient error which shows up while the job waits for a stream to get allocated for backup. If this is staying for long time and the job is not proceeding, please check if your storage pool has enough resources to serve the backup.
Sunil-
  • June 22, 2022
Hello Sunil ,
thank you so much, what i can do to showing tables in the content  ?
king regards .
Sunil
  • June 22, 2022
Hi @Adlene
Sunil-
  • June 22, 2022
Hi @Sunil
the sap version is 1.0 sps 12 ,
in need to,check sap bdd size and , a free space sockage on commvault allowed right ?
thanks
Sunil
  • June 23, 2022
Hi @Adlene
I’m sorry, I couldn’t get your question. Can you please clarify?
Sunil-
  • June 27, 2022
Hi Sunil ,
I will tray to rerun jobs and i  return to you
thank you
