Change path index cache
  • April 19, 2022
  • 1499 views
I have to change the path of the index cache on the MA, what can I do?
Thks
Dario
Best answer by Stuart Painter
Hi @DarioV
Thanks for the question, we have some documentation for this task:
Moving the Index Directory for an Index Server
Stuart
Hi @DarioV
Stuart
Jos Meijer
Forum|alt.badge.img+16
  • Community All Star
  • April 19, 2022
  • April 19, 2022
Hi Stuart,
I used the workflow "ChangeIndexCacheConfig" , it makes me change the path from C: \ Program Files \ Commvault \ ContentStore \ IndexCache to I: \ Program Files \ Commvault \ ContentStore \ IndexCache which is the correct one, the job is scheduled correctly but I fail
Thks
Dario
@DarioV , what messages do you receive when it fails?
Are those the correct source and destination paths?
