Changing the default port for a Unix install
  • September 20, 2023
  • 330 views
Hi Team,
I have an issue with an intended Unix client install.
Filesystem agent only.
We unfortunately have port 8400 occupied by other software, so I need to install to a different port.
However, I don’t see where i can over-ride 8400 with my intended port.
And for whatever reason, I can no longer find detailed instructions on the Unix\Linux install process.
I’m not a Unix admin, so probably like quite a few of us, it would be helpful if there was more detail on available options.
Bottom line, can someone advise how, or where I can provide a different port during a local install (I have a Unix tech available to assist).
RubeckDK
Novice
Forum|alt.badge.img+9
Hi @MountainGoat
I do not know on how to change the port number during the install process…. but after install you should be able to change the port by editing the /etc/CommVaultRegistry/Galaxy/Instance001/Session/.properties file on the client (and restart its services)
/RubeckDK
Rajiv
  • September 21, 2023
Hello @MountainGoat
As @RubeckDK mentioned, you can make changes to the file or can use additional setting as well, more information is present here: https://documentation.commvault.com/2023e/expert/7360_changing_network_ports.html
Best,
Rajiv Singal
Forum|alt.badge.img+2
  • October 2, 2023
you can pass the cvdport over the command line to override the default.
./cvpkgadd -cvdport 8500
Silent Install:
./silent_install -cvdport 8500
Narender
