Commvault on RedHat 8.2 not working
  • June 3, 2023
  • 129 views
Hi, could you help me please?
I'm installing Commvault version 11.30 on Linux RedHat 8.2. The installation was successful, but when I log in, I get the following error message below.
Error [0x80070306:{CCvNetwork::SendXDRMessageInternal(5343)} + {CCvNetwork::SendXDRMessagePrivate(5098)/W32.774.(One or more errors occurred while processing the request. (ERROR_ERRORS_ENCOUNTERED.774))-Message (0x34000220/APPMGR_HANDLE_XML_REQ) is not allowed from client (commvaultrhel/commvaultrhel.mycompany.com/SockIP(/opt/commvault/Base/Sockets/AppManager network access)/205.17.211.103:AppManager network access/0/0(AppManager network access) AppMgrSvc(136786:b980c700)) authenticated with built-in certificates.}] re-sending request to server.
Best answer by Gowri Shankar
Hi @Rafaelctt
Looks like the Linux server failed to pull the certificate from the CS.
Could you try to renew the certificate manually
https://documentation.commvault.com/2022e/expert/109473_renewing_revoked_certificate_in_typical_commcell_environment.html
If this fails then follow steps from the below link
https://documentation.commvault.com/2022e/expert/7522_renewing_revoked_certificate_in_locked_down_commcell_environment.html
Let us know if the issue still persists.
Gowri Shankar
Forum|alt.badge.img+13
Hi @Rafaelctt
Gowri Shankar
  • June 6, 2023
