Commvault SQL Database upgrade 2014 to 2016
  • 18 September 2023
  • 21 views
Hello All,
Greetings for the day!
We have running Physical windows cluster with commvault 11:24:116 version. The issue is during the SQL upgrade from the full media kit only active got upgraded from 2104 to 2016 but passive node still in 2014. Please share steps for manual upgrade on passive node.
Step1: Take the export Dump from SQL and DR backup from CV
Step2: Run the Select @@version on active node to collect the SQL version and SP
Step3: Download the SQL binary
Step4: Execute the setup.exe for upgrade
Step5: Test Fail over from active into passive
Regards
Robert
