Converting synthetic fulls to traditional ones if failing?
  • 11 May 2023
  • 35 views
Badge +10
Hi everyone..
Do such a setting exist? I mean, if a Synthetic Full backup job fails is there a way that it can convert it to a traditional one on the next re- try?  FS and VSA jobs are the ones, I’m interested in…
Thank you in advance..
Kind regards
Rubeck
Badge +8
Were you able to find out why the SynFull job failed?
Usually you can just run a Full manually or you can change it in the schedule, there’s no “conversion” its just the job type you want basically, is this what you’re trying to figure out?
