Edge Integration
  • April 17, 2022
  • 96 views
Forum|alt.badge.img+8
I would like to get confirmation about bellow requirements if its applicable or not .!!
 -  Drive With SharePoint and OneDrive On-Prim  ( Can Share File Or Folder Located on SharePoint Or OneDrive  From E-Drive Interface ).
 -    Integrate 2-Factore authenticator With our One Identity Defender To Centralized only one Token as we have defender as our token
 -    Need more elaboration for       DLP With Edge Drive . Is it has its own Data classification or we can integrate with third party Data classification application .
Best answer by Mike Struening
Here are some documents about the topics you mentioned:
SharePoint online:
https://documentation.commvault.com/11.24/essential/128530_sharepoint_online.html
Share server:
https://documentation.commvault.com/11.24/essential/99589_sharepoint_server.html
One-Drive:
https://documentation.commvault.com/11.24/essential/130942_backups_for_onedrive_for_business.html
MFA:
https://documentation.commvault.com/11.24/essential/107087_two_factor_authentication_for_your_commcell_environment.html
Please let me know if you have specific questions we can answer!
Hi @Muhammad Abdullah , hope all is well!
Can you clarify a bit here on what you are looking for?  Are you asking about authentication?
