Error Code: [24:64] Description: There was nothing to restore - subclient(s) not backed up
  • 11 April 2022
  • 676 views
Badge +1
I'm getting the error [24:64] Description: There was nothing to restore - subclient(s) not backed up.
When I do the restore of the virtual machine the restore works normally, but when I restore the guest files and folder, the commvault shows this error.
I can also browse the files normally, does anyone have any idea what might be going on? restores are for Nutanix AHV.
Best answer by Mike Struening RETIRED 12 April 2022, 15:48
@Sdmatos , this is indicating that the type of content you are trying to restore was not backed up based on your configuration.  It sounds like the node or cluster as a whole is getting backed up, but not anything file level.
Here’s the Expert level docs:
https://documentation.commvault.com/11.26/expert/31602_nutanix_acropolis_hypervisor_ahv.html
The Essential docs do say we can restore file level, though I’m not seeing anything detailing the configuration requirements, or restore methods:
https://documentation.commvault.com/11.26/essential/121686_nutanix_ahv.html
Can you confirm how you are backing up the AHV nodes?
