Error Code [72:106] Failure Reason
  • June 21, 2022
  • 2417 views
Hello Guys,
kindly find the error and help me resolve the issue.
Error Code
[72:106]
Failure Reason
The caller is out of memory or other system resources. The job will go to pending state and will be retried.
Best answer by naga
@Mike Struening  thanks for the reply!!
This is Hyper-V backup job error we faced.
we checked the job manager logs and found network issue.
I attached the error details
 Scheduler  Set pending cause [The job is pending because: Network receive failed: The network connection was lost unexpectedly.]:: Application [CVD] Message Id [] RCID [0] ReservationId [0].  Level [0] flags [0] id [0] overwrite [0] append [0] CustId[].
 Scheduler  Ignored pending cause [The job is pending because: Network receive failed: The network connection was lost unexpectedly.]::Client [] Application [CVD] Message Id [] RCID [0] Reservation Id [0].  Level [0] flags [0] id [0] overwrite [0] append [0] CustId[].
 Liveliness Abnormally terminated job detected for job
 Control    -- TERMINATE -- (killing processes -- [IsAlive] operation)
Scheduler  Ignored pending cause [Loss of control process vsbkp.exe.  Possible causes: 1. The control process has unexpectedly died. Check crash dump or core file. 2. The communication to the control process machine  might have gone down due to network errors. 3. If the machine  is a cluster, it may have failed over. 4. The machine  may have rebooted.]::Client [] Application [JobManager] Message Id [] RCID [0] Reservation Id [0].  Level [0] flags [0] id [0] overwrite [0] append [0] CustId[0].
 Scheduler  Phase [Failed] message received from [Job Manager] Module [JobManager] Token [] restartPhase [0]
 Delay Msg  successfully deleteSavedJMJobUpdateMsgByJob
JobSvr Obj Phase [4-Backup] for Backup Job Failed. Backup will continue with phase [Backup].
@naga , thanks for the post!
Can you provide some additional details?  What kind of agent is this?  What kind of operation?
I found some incidents with this error for Hyper-V backups.  In these cases, the issues were on the Hyper-V end (and the customers engaged Microsoft support to fix).
  • June 24, 2022
That’s it!  Were you able to resolve the issue on the network end?
